cpatterson
May 09, 2017Aspirant
SRX5308 , Maximum Entries Inbound Services
I am running a SRX5308 for one of our clients, managing access to multiple servers from outside their main facility. The simplest method for providing this access to this point has been port forwardi...
- Aug 02, 2017
By the way, if anyone ever comes back to this problem in the future, I got with someone who actually knows what they're doing in Netgear (props to Alex), and this is a shortcoming of this (and likely other netgear) routers: they can't manage over 64 individual rules.
DaneA
May 10, 2017NETGEAR Employee Retired
Hi cpatterson,
Kindly answer the questions below:
a. Have you double-checked the order of precedence of the Inbound rules that are currently configured on the SRX5308?
b. Have you tried to reboot the SRX5308 then check if all Inbound rules work?
c. Are there any changes made recently within the network setup where the SRX5308 is deployed?
d. What is the current firmware version of the SRX5308?
DaneA
NETGEAR Community Team
cpatterson
May 10, 2017Aspirant
Hi DaneA, thanks for your response.
a: the Order of the inbound services is exactly what I need it to be. I am blocking various addresses (the undesirables) before I do any of the port forwarding (required). We found that if you do the port forwarding first, the undesirable addresses get their junk forwarded before they can be blocked, which is, I assume, the point of having a precedence.
b: I have rebooted the SRX5308, but not when I was having the issue. I cannot verify the "blocked" addresses are still blocked (since they source from different countries), but Wireshark doesn't show any additional traffic from my "blocked" locations, and the forwarding works properly. However, once I crossed that "65 services" line, port forwarding stopped working, and I was required to physically visit the location. Once I removed the earliest two "blocked" addresses, the port forwarding started working again. None of this process required a reboot to change state.
c: No other changes are made within the network. I can replicate the issue (It happened once by accident, and once by intention to verify) simply by adding aditional services in the SRX5308 past the "65".
d: The current version of firmware on the device is 4.3.4-1. Is there some patch that addresses this limit? The last time I updated the firmware to a netgear device, it blew out all my added services and I had to scramble to re-add them. I had not done an update, since nothing in the patch notes I read indicated a change to this issue.
- cpattersonMay 12, 2017Aspirant
So, DaneA, any further input? thanks
- cpattersonMay 16, 2017Aspirant
Still having this issue, I'd like to see a resolution, or at least acknowledgement that this router can't handle the load. @DaneA, anyone else?
- DaneAMay 16, 2017NETGEAR Employee Retired
As far as we've checked, there is no issue on the SRX5308 as per you have described here on this forum thread. Let me check further on this and I will provide feedback as soon as I got an update.
DaneANETGEAR Community Team
