Charlieo
Nov 07, 2012Aspirant
SRX5308 and DSL on WAN2
Posted to the correct forum..... :-) I am trying to use a Verizion DSL modem on WAN2 for rollover when my WAN 1 cable modem goes down. The DSL modem is a Netgear DM111PSPv2. It works fine in Gatewa...
jmizoguchi
Nov 07, 2012Virtuoso
I think that's what I said I did in my original post. It works just fine when connected to a PC, in "modem-router"
did you test with DM111P in RFC bridge and hook up PC directly and do PPP dial up make sure it works that way.
Was not exactly... PPP dial up on PC while RFC bridge
My bad that did not clear the information
I was able to connect to a home router (Netgear WNDR 3700) and have it bring the WAN up perfectly.
if DM111P was on RFC bridge in this setup and works then contact support for issues on SRX5308
