Charlieo
Nov 07, 2012Aspirant
SRX5308 and DSL on WAN2
Posted to the correct forum..... :-) I am trying to use a Verizion DSL modem on WAN2 for rollover when my WAN 1 cable modem goes down. The DSL modem is a Netgear DM111PSPv2. It works fine in Gatewa...
Charlieo
Nov 08, 2012Aspirant
Outstanding!! I knew it had to be a simple answer!
So, just to be sure..... As long as WAN1 is up (and "green"), WAN2 will show as "down" and "yellow". Right?
That should be very easy to test. All I would need to do is unplug the WAN1 cable or turn off the WAN1 modem.....and WAN2 should come "up" and go green...... Correct? Is there any other way to test WAN2 in rollover mode? Can I change the mode to see both come up?
Thanks again. You saved me a bunch of heartache and time. This was/is driving me nuts.
Charlie
Charlie
