PopinatorWV
Oct 31, 2011Aspirant
SRX5308 Blocking Web sites
Hello all, I am trying to block a couple of web sites per managment. Followed instructions in manual about using content filtering. Can't seem to get it to work. Do I need to set up a user group? Ad...
jmizoguchi
Nov 01, 2011Virtuoso
doesn't matter which is must be first or not direction because it will uses groups once you added to LAN devices it should be taking affect and you can change lan devices at will so if you have block site enabled, just add lan devices to group
