DesignAlot
Dec 18, 2024Aspirant
[site blocked: 1d.tlu.dl.delivery.mp.microsoft.com]
I am getting MANY emails EVERY day, in regards to the Netgear log blocking the below site. How do I add this site to the safe list to stop getting tons of email alerts?! I have an AX9 RAX70 Nighthawk wifi 6 router.
[site blocked: 1d.tlu.dl.delivery.mp.microsoft.com] from source 192.168.1.33, Wednesday, December 18, 2024 13:46:09
Ok, I figured this out! I had site blocking on in my router settings based on certain keywords. I totally disabled the site blocking function, I stopped getting the site blocked notifications. This site that was blocked completely has to do with the Microsoft store app in my Windows 11. In my router, I looked up the two assigned ip addresses with the issues. They were my desktop PC and my Microsoft Surface Pro. I opened the Microsoft store app on both, and saw that an update was stuck on each device (both different product updates, this can happen with any one of them). When I quit the download/update attempt and then restarted the update attempts, I got the error log notice via email from my router! So after temporarily turning off the site block, I could finish the Microsoft store downloads/updates. I then enabled my site blocking again and no more notices for now. I will know what to do next time this happens. I have a daughter, so I have certain keywords that may be on websites blocked and I will continue to use this feature. At least I can identify which device, and check the Microsoft store app for "stuck" downloads. Hope this helps some people.
Do you have Armor, SPC or any filtering enabled on the router?
Is the device at .33 IP address a PC or some device that needs access to this site?
What FW version is loaded on the router?
- DesignAlotAspirant
I do not pay for the armor subscription, so I don't have that.
The ip that ends in .33 is my main computer, that I am responding to you on currently.
My firmware is up to date, the latest "V1.0.15.146"
Any other filtering or features enabled like Smart Parental Controls?
Does the PC get any traffic from this one site? Or is this a service site or web page?
Is there a problem accessing this site?
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
