NACC
Sep 16, 2015Tutor
SRX5308 Box to Box VPN with 192.168.0.0/18 Not Working
Hi, I've been using Netgear VPN routers/switches for many years and things have been solid during this time. We currently have two SRX 5308 units configured in a box-to-box VPN configuration betw...
JohnRo
Sep 16, 2015NETGEAR Employee Retired
Hello NACC,
Welcome to the community!
I have seen that error message before, this usually comes up when you are using the same remote WAN IP on another policy. Can you PM me the screenshots of the policies?
I'll look forward to your response.
Thanks,
- NACCSep 23, 2015Tutor
Hi John,
This took some doing, including recovering from several false starts and some inexplicable SRX5308 behaviour, but I was finally able to get this working. Indeed the key thing ended up being both/either of: 1) updating the Office A firmware to 4.3.3-5, and 2) *resetting* this router to factory defaults and *re-creating* its configuration manually.
I really can't come up with any root cause for why this didn't work before (or why the error message was displayed previously); the remote Office B SRX 5308 (running the older firmware) was never re-configured in any way.
-David
- JohnRoSep 23, 2015NETGEAR Employee Retired
Hello NACC,
I'm glad you got it to work, I also had a hard time trying to replicate the issue so I wasn't able to get back to you right away. Did not see any notes on the older firmware that you have used regarding VPN. If you have any more questions, I'll be happy to assist.
Thanks,
