argylegp
Mar 25, 2015Novice
SRX5308 Firewall example
I have two SRX5308 routers in different Cities with different ISP's. Setup will be: WAN1 to the ISP, for internet access, VPN tunnel, and VPN Client access. LAN1 will be to inside. Does anyone hav...
Nhellie
Mar 25, 2015Virtuoso
argylegp wrote:
First: I have two SRX5308 routers for Site-A and Site-B. Both sites have internet access. Site-A is the main office where the servers are, Site-B has to access Site-A through a VPN tunnel.
Second: Site-A is also a VPN access point for VPN-client software to login.
Third: The firewalls have to allow - LogMeIn, RDP, FTP, and VPN-client to pass through.
1. You can achieve this by setting up Box-to-Box VPN connection.
2. This can be done by the Client-to-Box setup.
Examples are on the links that I posted above.
3. You will need to setup port forwarding for these. Check the link below for instructions:
http://kb.netgear.com/app/answers/detail/a_id/1002/~/port-forwarding-on-the-fvs318v3
