argylegp
Mar 25, 2015Novice
SRX5308 Firewall example
I have two SRX5308 routers in different Cities with different ISP's. Setup will be: WAN1 to the ISP, for internet access, VPN tunnel, and VPN Client access. LAN1 will be to inside. Does anyone hav...
Nhellie
Mar 25, 2015Virtuoso
On the client software, you will have to enter the internal IP of the remote network.
http://support1.gearguy.com/useruploads/images/Client_create_3%281%29.png
Check this link below:
http://kb.netgear.com/app/answers/detail/a_id/24245/~/client-to-box-vpn
