argylegp
Mar 25, 2015Novice
SRX5308 Firewall example
I have two SRX5308 routers in different Cities with different ISP's. Setup will be: WAN1 to the ISP, for internet access, VPN tunnel, and VPN Client access. LAN1 will be to inside. Does anyone hav...
adit
Mar 25, 2015Mentor
Read my LAN Subnets NOT to Use tutorial for an explanation.
LogMeIn should requires no router setttings.
You should not open 3389 (RDP) to the Internet. It's a huge security issue.
If the public needs access to the FTP then feel free to open the port(s).
VPN Passthrough is only for outbound initiated VPN Client tunnels. It has nothing to do with inbound (to the SRX) VPN Client tunnel access.
You may have to adjust the software firewalls on the servers to allow the VPN Client subnet access. It all depends on how they are setup.
