Phil_C
Sep 30, 2026Aspirant
SRX5308 Internet Issues
Hello All I have a 24port FSM726S managed switch connected to a SRX5308 that is also set up as the DNS server. To the switch is also connected a Nighthawk Rax9 and previously a R7000. The problem ...
Sep 30, 2026Guru - Experienced User
Phil_C wrote:If I connect my laptop with a cable it works fine and the internet is accessible however as soon as I try to use the wireless on the laptop the internet is blocked.
Is the Rax9 set up in AP mode?
Is that cable connected connected to a Rax9 LAN port, or is it connected to the switch?
If the switch, have you tried testing the Rax9 LAN port connections?
Do you use MAC ACL to block connections in the SRX5308 (or the RAX9) ?
