sdchris
May 04, 2023Aspirant
CM1100 Intermittent internet issue with COX
Hello all,
I have been having issues with my CM1100 disconnecting from the internet. I have had the modem for about 2 years and not sure how long the connection issue has been going on. I called Cox and of course everything on there end looks great and they blame the modem. So I wanted to post some of my logs and see if the power s/n ratio looks good. Thanks in advance for taking a look. 😁
| Frequency start Value | |
| This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | |
<tabindex=-1>Startup Procedure</tabindex=-1>
| Procedure | Status | Comment |
| Acquire Downstream Channel | 237000000 Hz | Locked |
| Connectivity State | OK | Operational |
| Boot State | OK | Operational |
| Security | Enable | BPI+ |
| IP Provisioning Mode | Honor MDD | IPv4 only |
<tabindex=-1>Downstream Bonded Channels</tabindex=-1>
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR / MER | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords |
| 1 | Locked | QAM256 | 45 | 237000000 Hz | 11.4 dBmV | 45.3 dB | 143251340 | 2640 | 1507 |
| 2 | Locked | QAM256 | 1 | 735000000 Hz | 7.5 dBmV | 42.4 dB | 141409643 | 2115 | 638 |
| 3 | Locked | QAM256 | 2 | 741000000 Hz | 8.3 dBmV | 42.9 dB | 141414917 | 2122 | 561 |
| 4 | Locked | QAM256 | 3 | 747000000 Hz | 8.4 dBmV | 42.9 dB | 141418284 | 2070 | 573 |
| 5 | Locked | QAM256 | 4 | 753000000 Hz | 8.4 dBmV | 42.9 dB | 141422194 | 2173 | 542 |
| 6 | Locked | QAM256 | 5 | 759000000 Hz | 7.9 dBmV | 42.6 dB | 141425713 | 2072 | 534 |
| 7 | Locked | QAM256 | 6 | 765000000 Hz | 8.4 dBmV | 42.9 dB | 141430804 | 1934 | 516 |
| 8 | Locked | QAM256 | 7 | 771000000 Hz | 8.3 dBmV | 42.8 dB | 141434486 | 1991 | 513 |
| 9 | Locked | QAM256 | 8 | 777000000 Hz | 8.4 dBmV | 43.0 dB | 141438058 | 2020 | 494 |
| 10 | Locked | QAM256 | 25 | 117000000 Hz | 12.5 dBmV | 44.5 dB | 141442962 | 746 | 285 |
| 11 | Locked | QAM256 | 26 | 123000000 Hz | 12.6 dBmV | 44.8 dB | 141446910 | 882 | 280 |
| 12 | Locked | QAM256 | 27 | 129000000 Hz | 12.7 dBmV | 44.9 dB | 141450389 | 1015 | 307 |
| 13 | Locked | QAM256 | 28 | 135000000 Hz | 12.6 dBmV | 44.5 dB | 141452905 | 1613 | 1064 |
| 14 | Locked | QAM256 | 29 | 141000000 Hz | 12.3 dBmV | 44.6 dB | 141453165 | 1817 | 4162 |
| 15 | Locked | QAM256 | 30 | 147000000 Hz | 12.4 dBmV | 44.8 dB | 141457810 | 1637 | 3286 |
| 16 | Locked | QAM256 | 31 | 153000000 Hz | 12.2 dBmV | 44.9 dB | 141463110 | 1374 | 2212 |
| 17 | Locked | QAM256 | 32 | 159000000 Hz | 12.2 dBmV | 45.1 dB | 141467612 | 1521 | 1334 |
| 18 | Locked | QAM256 | 33 | 165000000 Hz | 12.1 dBmV | 45.1 dB | 141471867 | 1098 | 1111 |
| 19 | Locked | QAM256 | 34 | 171000000 Hz | 11.8 dBmV | 45.1 dB | 141474489 | 1974 | 1284 |
| 20 | Locked | QAM256 | 35 | 177000000 Hz | 12.1 dBmV | 45.3 dB | 129954113 | 2459 | 336 |
| 21 | Locked | QAM256 | 36 | 183000000 Hz | 11.9 dBmV | 45.1 dB | 141480873 | 2998 | 1348 |
| 22 | Locked | QAM256 | 37 | 189000000 Hz | 11.7 dBmV | 45.2 dB | 141484595 | 2805 | 1051 |
| 23 | Locked | QAM256 | 38 | 195000000 Hz | 11.3 dBmV | 45.1 dB | 141490194 | 1597 | 859 |
| 24 | Locked | QAM256 | 39 | 201000000 Hz | 11.3 dBmV | 45.1 dB | 141494868 | 1077 | 640 |
| 25 | Locked | QAM256 | 40 | 207000000 Hz | 11.2 dBmV | 45.2 dB | 141497954 | 1257 | 427 |
| 26 | Locked | QAM256 | 41 | 213000000 Hz | 11.3 dBmV | 45.1 dB | 141502268 | 1384 | 259 |
| 27 | Locked | QAM256 | 42 | 219000000 Hz | 11.1 dBmV | 45.0 dB | 141505944 | 1306 | 288 |
| 28 | Locked | QAM256 | 43 | 225000000 Hz | 11.1 dBmV | 45.1 dB | 141509352 | 1365 | 298 |
| 29 | Locked | QAM256 | 44 | 231000000 Hz | 11.2 dBmV | 45.3 dB | 141513150 | 1409 | 302 |
| 30 | Locked | QAM256 | 46 | 243000000 Hz | 11.6 dBmV | 45.3 dB | 141511526 | 1795 | 1623 |
| 31 | Locked | QAM256 | 47 | 249000000 Hz | 11.7 dBmV | 45.2 dB | 141514186 | 1555 | 1116 |
| 32 | Locked | QAM256 | 48 | 255000000 Hz | 12.0 dBmV | 45.2 dB | 141513880 | 1458 | 492 |
<tabindex=-1>Upstream Bonded Channels (Partial Service)</tabindex=-1>
| 1 | Locked | ATDMA | 1 | 17600000 Hz | 48.3 dBmV |
| 2 | Locked | ATDMA | 2 | 24000000 Hz | 48.3 dBmV |
| 3 | Locked | ATDMA | 3 | 30400000 Hz | 48.8 dBmV |
| 4 | Locked | ATDMA | 4 | 36800000 Hz | 49.5 dBmV |
| 5 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
| 6 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
| 7 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
| 8 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
<tabindex=-1>Downstream OFDM Channels</tabindex=-1>
| Channel | Lock Status | Modulation / Profile ID | Channel ID | Frequency | Power | SNR / MER | Active Subcarrier Number Range | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords |
| 1 | Locked | 0, 1 | 159 | 300000000 Hz | 12.2 dBmV | 42.8 dB | 296 ~ 7895 | 459227490 | 5046213 | 364 |
| 2 | Locked | 0, 1, 2, 3 | 160 | 918000000 Hz | 4.5 dBmV | 37.8 dB | 1108 ~ 2987 | 177785436 | 77737124 | 1434 |
<tabindex=-1>Upstream OFDMA Channels</tabindex=-1>
| 1 | Not Locked | 3, 4, 9, 10, 11, 12, 13 | 6 | 36800000 Hz | 48.5 dBmV |
| 2 | Not Locked | 3, 4, 9, 10, 11, 12, 13 | 0 | 0 Hz | 0.0 dBmV |
Power levels are way too high:
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
Any Criticals, Errors or Warnings needs to be reviewed by the ISP and resolved and power turned down up to the modem:
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/
- sdchrisAspirant
Here are the latest logs:
2023-05-04, 13:54:08 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=bc:a5:11:d3:c7:ec;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:54:05 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:54:04 Notice (6) CM-STATUS message sent. Event Type Code: 20; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=XXX;MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:54:01 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:54:00 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159 160; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2 3.;CM-MAC=XXX;MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:53:55 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;MAC=XXX;MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:53:54 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=bc:a5:11:d3:c7:ec;MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:53:51 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:52:33 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: 1; New Profile: 1 2 3.;CM-MAC=bc:a5:11:d3:c7:ec;MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:52:15 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:52:12 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 8;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:52:12 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:51:32 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=bc:a5:11:d3:c7:ec;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:51:31 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:51:23 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:51:19 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:50:49 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:50:43 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:50:41 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=bc:a5:11:d3:c7:ec;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:50:40 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:50:37 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:50:35 Critical (3) SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:50:33 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=bc:a5:11:d3:c7:ec;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:50:32 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 8;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:50:32 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:49:54 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=XXX;MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:49:53 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:49:49 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:49:48 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:49:40 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:49:39 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:49:32 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:49:30 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:49:14 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:49:05 Critical (3) SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:49:05 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:48:56 Critical (3) SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:48:54 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:48:52 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 8;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 13:48:52 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; Here is the log from the last time the internet went down earlier today:
2023-05-04, 11:05:02 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 11:04:34 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2.;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 11:04:19 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 11:03:49 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 11:03:49 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2.;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 11:02:49 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 11:02:49 Warning (5) Dynamic Range Window violation 2023-05-04, 11:02:49 Warning (5) RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 11:02:49 Warning (5) Dynamic Range Window violation 2023-05-04, 11:02:49 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 11:02:49 Warning (5) Dynamic Range Window violation 2023-05-04, 11:02:49 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 11:02:49 Warning (5) Dynamic Range Window violation 2023-05-04, 11:02:49 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 11:02:49 Warning (5) Dynamic Range Window violation 2023-05-04, 11:02:49 Warning (5) RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 11:02:45 Notice (6) DS profile assignment change. DS Chan ID: 33; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 11:02:43 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2.;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 11:02:38 Notice (6) TLV-11 - unrecognized OID;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-04, 11:02:38 Warning (5) DHCP WARNING - Non-critical field invalid in response ;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv4 Time Not Established Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) UCD invalid or channel unusable;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; - FURRYe38Guru - Experienced User
Power levels are too high:
ISP needs to bring them down.
Lots of Correctables and Un-Correctables that should be zeros.
Lots of criticals and warnings that the ISP needs to review and resolve:
https://highspeed.tips/docsis-events/ - sdchrisAspirant
I connected the modem outside directly to the coax coming from the street and bypassed a splitter and here are the numbers:
<tabindex=-1>Startup Procedure</tabindex=-1> Procedure Status Comment Acquire Downstream Channel 237000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enable BPI+ IP Provisioning Mode Honor MDD IPv4 only <tabindex=-1>Downstream Bonded Channels (Partial Service)</tabindex=-1> Channel Lock Status Modulation Channel ID Frequency Power SNR / MER Unerrored Codewords Correctable Codewords Uncorrectable Codewords 1 Locked QAM256 45 237000000 Hz 15.3 dBmV 44.5 dB 36098425 149 24 2 Locked QAM256 1 735000000 Hz 15.7 dBmV 43.6 dB 33903906 408 6 3 Locked QAM256 2 741000000 Hz 16.0 dBmV 43.8 dB 33908284 332 4 4 Locked QAM256 3 747000000 Hz 16.0 dBmV 43.9 dB 33911752 355 12 5 Locked QAM256 4 753000000 Hz 15.9 dBmV 43.8 dB 33915559 336 4 6 Locked QAM256 5 759000000 Hz 15.7 dBmV 43.6 dB 33919459 279 0 7 Locked QAM256 6 765000000 Hz 15.5 dBmV 43.5 dB 33922634 299 3 8 Locked QAM256 7 771000000 Hz 15.8 dBmV 43.6 dB 33927371 244 3 9 Locked QAM256 8 777000000 Hz 15.8 dBmV 43.8 dB 33930947 237 0 10 Locked QAM256 25 117000000 Hz 14.4 dBmV 43.2 dB 33934887 13 0 11 Locked QAM256 26 123000000 Hz 14.7 dBmV 43.2 dB 33938564 33 0 12 Locked QAM256 27 129000000 Hz 14.8 dBmV 43.3 dB 33942402 18 0 13 Locked QAM256 28 135000000 Hz 14.7 dBmV 43.3 dB 33945838 125 0 14 Locked QAM256 29 141000000 Hz 14.5 dBmV 43.2 dB 33948993 554 54 15 Locked QAM256 30 147000000 Hz 14.7 dBmV 43.6 dB 33952432 508 259 16 Locked QAM256 31 153000000 Hz 14.6 dBmV 43.8 dB 33956375 433 361 17 Locked QAM256 32 159000000 Hz 14.7 dBmV 43.9 dB 33960634 540 66 18 Locked QAM256 33 165000000 Hz 14.7 dBmV 43.9 dB 33964201 260 405 19 Locked QAM256 34 171000000 Hz 14.6 dBmV 43.8 dB 33968354 174 459 20 Locked QAM256 35 177000000 Hz 14.9 dBmV 44.1 dB 33972087 141 472 21 Locked QAM256 36 183000000 Hz 14.8 dBmV 44.2 dB 33975932 138 473 22 Locked QAM256 37 189000000 Hz 14.7 dBmV 44.2 dB 33978681 148 461 23 Locked QAM256 38 195000000 Hz 14.5 dBmV 44.0 dB 33983423 154 429 24 Locked QAM256 39 201000000 Hz 14.7 dBmV 44.3 dB 33987229 361 201 25 Locked QAM256 40 207000000 Hz 14.9 dBmV 44.3 dB 33991252 170 31 26 Locked QAM256 41 213000000 Hz 15.1 dBmV 44.2 dB 33994783 76 36 27 Locked QAM256 42 219000000 Hz 14.8 dBmV 44.2 dB 33998955 55 38 28 Locked QAM256 43 225000000 Hz 15.0 dBmV 44.3 dB 34002396 47 37 29 Locked QAM256 44 231000000 Hz 15.1 dBmV 44.3 dB 34006366 46 36 30 Locked QAM256 46 243000000 Hz 15.3 dBmV 44.5 dB 34006401 187 2 31 Locked QAM256 47 249000000 Hz 15.3 dBmV 44.3 dB 34007603 210 0 32 Locked QAM256 48 255000000 Hz 15.4 dBmV 44.4 dB 34007090 147 2 <tabindex=-1>Upstream Bonded Channels (Partial Service)</tabindex=-1> Channel Lock Status Modulation Channel ID Frequency Power 1 Locked ATDMA 1 17600000 Hz 45.5 dBmV 2 Locked ATDMA 2 24000000 Hz 45.5 dBmV 3 Locked ATDMA 3 30400000 Hz 46.0 dBmV 4 Locked ATDMA 4 36800000 Hz 45.8 dBmV 5 Not Locked Unknown 0 0 Hz 0.0 dBmV 6 Not Locked Unknown 0 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Hz 0.0 dBmV <tabindex=-1>Downstream OFDM Channels</tabindex=-1> Channel Lock Status Modulation / Profile ID Channel ID Frequency Power SNR / MER Active Subcarrier Number Range Unerrored Codewords Correctable Codewords Uncorrectable Codewords 1 Locked 0, 1, 2, 3 159 300000000 Hz 15.3 dBmV 42.3 dB 296 ~ 7895 130273818 3964244 395 2 Locked 0, 1, 2, 3 160 918000000 Hz 13.4 dBmV 41.0 dB 1108 ~ 2987 37576456 6917188 285 <tabindex=-1>Upstream OFDMA Channels</tabindex=-1> Channel Lock Status Modulation / Profile ID Channel ID Frequency Power 1 Not Locked 3, 4, 9, 10, 11, 12, 13 6 36800000 Hz 40.8 dBmV 2 Not Locked 3, 4, 9, 10, 11, 12, 13 0 0 Hz 0.0 dBmV - sdchrisAspirant
Here is the latest log:
Time
Priority Description 2023-05-05, 09:27:53 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 160; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1.;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-05, 09:27:33 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159 160; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2 3.;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-05, 09:27:32 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-05, 09:27:28 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-05, 09:27:27 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159 160; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2 3.;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-05, 09:27:26 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-05, 09:27:25 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159 160; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 3.;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-05, 09:27:19 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-05, 09:27:16 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 8;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-05, 09:27:16 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-05, 09:27:16 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-05, 09:26:54 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-05, 09:26:27 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-05, 09:21:57 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-05, 09:21:57 Warning (5) Dynamic Range Window violation 2023-05-05, 09:21:57 Warning (5) RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-05, 09:21:54 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-05, 09:21:53 Notice (6) CM-STATUS message sent. Event Type Code: 3; Chan ID: N/A; DSID: �; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-05, 09:21:52 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-05, 09:21:52 Warning (5) Unicast DSID PSN startup error 2023-05-05, 09:21:52 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-05, 09:21:52 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-05, 09:20:52 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-05, 09:20:52 Warning (5) Dynamic Range Window violation 2023-05-05, 09:20:52 Warning (5) RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-05, 09:20:52 Warning (5) Dynamic Range Window violation 2023-05-05, 09:20:52 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-05, 09:20:52 Warning (5) Dynamic Range Window violation 2023-05-05, 09:20:52 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-05, 09:20:52 Warning (5) Dynamic Range Window violation 2023-05-05, 09:20:52 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-05, 09:20:52 Warning (5) Dynamic Range Window violation 2023-05-05, 09:20:52 Warning (5) RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-05, 09:20:47 Notice (6) DS profile assignment change. DS Chan ID: 33; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-05, 09:20:46 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-05, 09:20:41 Notice (6) TLV-11 - unrecognized OID;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; 2023-05-05, 09:20:40 Warning (5) DHCP WARNING - Non-critical field invalid in response ;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv4 Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) UCD invalid or channel unusable;CM-MAC=XXX;CM-MAC=XXX;CM-QOS=1.1;CM-VER=3.1; - FURRYe38Guru - Experienced User
