sdchris
May 04, 2023Aspirant
CM1100 Intermittent internet issue with COX
Hello all, I have been having issues with my CM1100 disconnecting from the internet. I have had the modem for about 2 years and not sure how long the connection issue has been going on. I called Cox...
- May 05, 2023
Power levels are way too high:
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
Any Criticals, Errors or Warnings needs to be reviewed by the ISP and resolved and power turned down up to the modem:
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/
May 04, 2023Guru - Experienced User
Power levels are too high:
ISP needs to bring them down.
Lots of Correctables and Un-Correctables that should be zeros.
Lots of criticals and warnings that the ISP needs to review and resolve:
sdchris
Thanks I will give them a call.
