bhoth
Jan 10, 2017Aspirant
SRX5308 Ipv6 problems with Comcast
Hi All, after installing the most recent firmware I decided to finally turn on IPv6. My ISP is Comcast and they tell me they are fully compatible and ready to go with IPv6. After selecting IPv4 /...
ChenX
Jan 10, 2017NETGEAR Expert
Hi bhoth
Welcome to the community! ![]()
Kindly answer the questions below:
1.Did the Comcast support DHCPV6 or PPPOE?
Let me share the article below and it might help:
How to Configure Dynamic IPv6 Connection on a PROSAFE Firewall
Regards
- bhothJan 10, 2017Aspirant
Hi I found the document "How to Configure Dynamic IPv6 Connection on a PROSAFE Firewall.pdf" from another thread and it got me going.
Thank you,
- JohnRoJan 11, 2017NETGEAR Employee Retired
Hi bhoth,
We are glad to know that one of our KB's helped you out. If this fixes your issue we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
- DaneAJan 15, 2017NETGEAR Employee Retired
@both,
If ever your concern has been resolved using the KB article you've found, we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
- chrisklemmJan 29, 2017Aspirant
SO - where is this document? Searching this forum, and google for "How to Configure Dynamic IPv6 Connection on a PROSAFE Firewall.pdf" only brings you to THIS page..
Does anyone know where this mysterious document or KB article is?
- DaneAJan 30, 2017NETGEAR Employee Retired
Welcome to the community! :)
Here is the article: How to Configure Dynamic IPv6 Connection on a PROSAFE Firewall
Note: If you scroll up and look for the response of ChenX, he also provided a link for the same article (with the same title) you are looking for.
Hope it helps.
DaneA
