MWisniewski
Apr 11, 2018Tutor
SRX5308 IPv6 routing
While I know that I should consider this piece of equipment being my new paper weight, I just want answer to following question: How to make it pass IPv6 to next router? Right now I have proper conf...
- Apr 13, 2018
Do you think it would be possible to configure IPv6 without dual stack enabled? However say it is fixed - after full wipe. Not a first time this procedure helped.
JohnC_V
Apr 12, 2018NETGEAR Employee Retired
Hi MWisniewski,
Have you tried setting up the firewall to IPv4/IPv6 Mode?
