Golgotha
Feb 01, 2017Aspirant
SRX5308 multi wan connexion UP
I have an SRX5308 with two WANs (a 100Mb WAN1 fuse and an adsl 5Mb WAN2 backup) I need both links to be up all the time (as in load balancing mode) because there are open ports on the Two links, but ...
- Feb 15, 2017
Hi Golgotha,
Were you able to test using LB and firewall rules? Let us know if you need more help.
Thanks,
Golgotha
Feb 02, 2017Aspirant
Thank you for this quick response, i understand the operation. On the other hand the use I wanted to make was a little different. The WAN1 must be used for all outgoing calls and some incoming calls. WAN2 should only be used for incoming calls on certain ports (VOIP). If I configure in WAN1 alone, then WAN2 is always "down" if I configure in LB then the outgoing traffic is distributed on both WAN
thank's
JohnRo
Feb 03, 2017NETGEAR Employee Retired
Hi Golgotha,
I don't see this is an available feature as of the moment. I am thinking you can use firewall LAN WAN rules instead, with rules you can direct which WAN port is used by the traffic of the specific port/service. See image below as reference:
For more information, see Firewall Protection on the User Manual page 176.
Thanks,
