Golgotha
Feb 01, 2017Aspirant
SRX5308 multi wan connexion UP
I have an SRX5308 with two WANs (a 100Mb WAN1 fuse and an adsl 5Mb WAN2 backup) I need both links to be up all the time (as in load balancing mode) because there are open ports on the Two links, but ...
- Feb 15, 2017
Hi Golgotha,
Were you able to test using LB and firewall rules? Let us know if you need more help.
Thanks,
Golgotha
Feb 02, 2017Aspirant
Thank you for this quick response, i understand the operation. On the other hand the use I wanted to make was a little different. The WAN1 must be used for all outgoing calls and some incoming calls. WAN2 should only be used for incoming calls on certain ports (VOIP). If I configure in WAN1 alone, then WAN2 is always "down" if I configure in LB then the outgoing traffic is distributed on both WAN
thank's
JohnRo
Feb 06, 2017NETGEAR Employee Retired
Hi Golgotha,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
- GolgothaFeb 06, 2017Aspirant
sorry I' havent seen your last message ...
The only solution seem to use load_balancing & firewall rules, but i have'nt tried now I will do that un february 13/14/15
Il will close after.
Thank's a lot
- JohnRoFeb 07, 2017NETGEAR Employee Retired
Hi Golgotha,
Let us know if this works for you. I'll see of I can find another way for you but this one seems to be a good way to limit the bandwidth usage.
Thanks,
- JohnRoFeb 15, 2017NETGEAR Employee Retired
Hi Golgotha,
Thanks,
- GolgothaFeb 15, 2017Aspirant
YESSS.
we dit it yesterday
in load balancing mode, with to firewall rules its perfect.
I have 2 vlans (one for internet data, one for voip & viop services such as teleworkers) VLAN0 (default) for internet is on the 100 Mb fibre, and VLAN1 (voip & teleworker) is on SDSL
All is OK Thank's a lot for your help.
