Golgotha
Feb 01, 2017Aspirant
SRX5308 multi wan connexion UP
I have an SRX5308 with two WANs (a 100Mb WAN1 fuse and an adsl 5Mb WAN2 backup) I need both links to be up all the time (as in load balancing mode) because there are open ports on the Two links, but ...
- Feb 15, 2017
Hi Golgotha,
Were you able to test using LB and firewall rules? Let us know if you need more help.
Thanks,
JohnRo
Feb 07, 2017NETGEAR Employee Retired
Hi Golgotha,
Let us know if this works for you. I'll see of I can find another way for you but this one seems to be a good way to limit the bandwidth usage.
Thanks,
JohnRo
Feb 15, 2017NETGEAR Employee Retired
Hi Golgotha,
Thanks,
- GolgothaFeb 15, 2017Aspirant
YESSS.
we dit it yesterday
in load balancing mode, with to firewall rules its perfect.
I have 2 vlans (one for internet data, one for voip & viop services such as teleworkers) VLAN0 (default) for internet is on the 100 Mb fibre, and VLAN1 (voip & teleworker) is on SDSL
All is OK Thank's a lot for your help.
- JohnRoFeb 16, 2017NETGEAR Employee Retired
Hi Golgotha,
You're welcome! Have a great day!
Thanks,
