regrossman
Aug 10, 2013Novice
SRX5308 Multiple Public IP
I bought an SRX5308 to setup in one of our remote offices. I'm utilizing several IP addresses on both the WAN1 and WAN2 connections. When I'm opening up the firewall, on the FVX538 there was the option to set WAN Destination IP Address to one of those public static IPs that are different then the WAN1 address. On the SRX5308, there is no option to pick another ip address, only a range option and if I pick the range option and put the IP in as the start and end, it says the end must be greater then the start but I want to assign this to a single IP. Can the FVX538 do what the SRX5308 cannot? This is firmware version 3.0.8 on the SRX.
- jmizoguchiVirtuosoWAN user drop down should have single
- darrenbAspirantthe drop down does not have single ip - i do not understand why this is different to the FVS336 if i can route my dmz to a different external ip to the wan 1 then these units are no good to me.
can you suggest how i can?
thanks
Darren - aditMentorEdit the WAN settings and look up top for Secondary Addresses. Enter additional WAN IP addresses there. Those additional WAN IP addresses will then appear in the drop down fields.
