BillyRed
Mar 13, 2018Aspirant
SRX5308 not able to save WAN1 config info
I add WAN1 configuration information and then apply. When I test the connection, all zeros are in the configuration fields. Test Fails.
- Mar 19, 2018
I finally discovered a bad rj45 connector at the AT&T Router. The Netgear would not save the config without having a network signal. Replaced end and all is good. Thanks everyone for taking time to help with my problem...
JohnC_V
Mar 19, 2018NETGEAR Employee Retired
I would like to have a follow up on this thread. Please let us know if everything is ok now or you still need further assistance.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
BillyRed
Mar 19, 2018Aspirant
