MBau
Dec 19, 2016Aspirant
SRX5308 Only two IPSEC Channels working over same IKE
Hello, I have configured two SRX5308 (R1, R2) to connect over a IKE Channel (IKE1). This channel were used by three IP-Sec Channels (IPSEC1 - IPSEC3). All Channels are configured with the same su...
DaneA
Dec 20, 2016NETGEAR Employee Retired
Hi MBau,
Welcome to the community! :)
Kindly post a .img or .png image of your detailed network diagram as well as the settings you have configured on both SRX5308.
What is the current firmware version of both SRX5308?
DaneA
NETGEAR Community Team
- MBauDec 21, 2016Aspirant
Hello DaneA,
thank you for your fast reply.
Here´s a simplified image. Through one IKE Tunnel should routed three IPSec Tunnels with different subnets.
Following the full detailed image to show the real wireing.
Most routers don´t (or didn´t) support routing from vpn to vpn. And if they do, debugging is nearly not possible. So our department build up a IKE Connections to a separeted Router behind the main router realized with destination NAT (Portforwarding on matching source IP). Now it is possible to route to customer VPNs usinge a transfer network.
It works! But only with two of three IPSEC Tunnels. With two random tunnels! Sometimes tunnel one and two. Sometime tunnel two and three.Best regards
P.S: Firmware: 4.3.4-2
IKE: Preshared Key - Aggressive - AES256 - SHA1 - DH5 - 28800s Lifetime - DPD on
IPSEC: AES256 - SHA1 - DH5 - 3600s- DaneAJan 31, 2017NETGEAR Employee Retired
MBau,
I have inquired your concern to a higher tier of NETGEAR Support. On the SRX5308, 125 IPSec VPN policies can run concurrently using the same IKE policy, but the remote endpoint should be same for all IPSec VPN policies using the same IKE policy.
Kindly check that all remote endpoint are the same for all IPSec VPN policies. Also, when one of the policies does not connect, kindly provide the VPN logs relating to this policy to be reviewed.
DaneA
- JohnRoFeb 03, 2017NETGEAR Employee Retired
Hi MBau,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
