Y0tsuya
Feb 10, 2012Aspirant
SRX5308 secondary IP port forwarding
Just got a brand new SRX5308 to replace a dependable but somewhat underpowered FVS336g. I spent the past few days trying to get it to do simple port forwarding on a secondary IP. I tried 3.0.7-29 an...
rbart
Feb 25, 2012Aspirant
I found via level 2 support that if both IP's are on the same subnet, the second address just does not work... May want to confirm that when you call them if that is your case.
