Rb33
Oct 01, 2013Aspirant
SRX5308 slow IPSec
Hi, I've searched the forums and haven't found any solution to my problem. When I use IPSec tunnel with the SRX5308 I have very long response times, it feels like it takes forever to establish the ...
Rb33
Oct 02, 2013Aspirant
jmizoguchi wrote: what speed you do get in the tunnel
According to speedtest.net I get 40Mbps and 48ms response time, the problem isn't the speed, the problem is the time it takes to establish the connection. The problem does only appear with IPSec, I tried pptp and that works fine.
