shlomim's avatar
shlomim
SRX5308 Unable to setup second WAN connection
Hi,   In my company we have the SRX5308 with WAN1 configured as: IPV4 Static IP and it is working just fine (The VDSL is a modem/router configured as dailer and one port connected to the netgear w...
  • DaneA's avatar
    DaneA
    Aug 02, 2016
    Hi shlomim,
    You're welcome! :)  I am glad that its all sorted out.
    Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    Cheers,
    DaneA
    NETGEAR Community Team
ProSupport for Business
