shlomim
Jul 20, 2016Aspirant
SRX5308 Unable to setup second WAN connection
Hi, In my company we have the SRX5308 with WAN1 configured as: IPV4 Static IP and it is working just fine (The VDSL is a modem/router configured as dailer and one port connected to the netgear w...
- Aug 02, 2016
Hi shlomim,
You're welcome! :) I am glad that its all sorted out.
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
NETGEAR Community Team
DaneA
Jul 25, 2016NETGEAR Employee Retired
Hi shlomim,
Welcome to the community! :)
Since WAN 1 port is working fine with the VDSL connection as you have mentioned, what if you try to set it on WAN 2 port (or WAN 3 & WAN 4 ports). Then, set WAN 1 port (or WAN 3 & WAN 4 ports) for the new VDSL modem in order to isolate the problem. Let us know the results.
DaneA
shlomim
Aug 02, 2016Aspirant
Hi,
Thanks for your response.
It seems like it was my misunderstanding, When selecting Primary WAN Mode as WAN1 and Auto Rollover fr the scond WAN, it causes only 1 WAN to be connected.
I thought that both of them will always be connected and only if WAN1 will disconnect the traffic will go throw the second WAN.
Thanks for your help!
- DaneAAug 02, 2016NETGEAR Employee Retired
Hi shlomim,
Cheers,DaneA
