Aquajulien81
Oct 13, 2020Aspirant
SRX5308 VLAN2 ACROSS VPN
Hi, since lot of years, we have an VPN between 2 sites. ALL DEVICES ARE IN FIXED IP. We have lot of cellular phone on wifi and we want they can connect wifi wathever the site they are. So we have a...
Aquajulien81
Oct 14, 2020Aspirant
Here the VPN configuration of Site1 (working):
http://ftpdepot.free.fr/netgear_site1_to_site2_IKE_POLICY.JPG
http://ftpdepot.free.fr/netgear_site1_to_site2_VPN_POLICY.JPG
For my LAN2 (10.92.10.xxx), must i create a new VPN ?
DaneA
Nov 11, 2020NETGEAR Employee Retired
Welcome to the community! :)
It might be possible that the cause of the problem is that 10.92.10.xxx LAN WiFi on Site 1 has the same IP Subnet on the LAN WiFi on Site 2 which is 10.92.10.xxx as well. Kindly try to change the IP Subnet on LAN WiFi Site 2 to a different subnet (for example: 10.92.20.xxx).
Just wanted to know. How about the 10.92.1.xxx from Site 1, are they able to communicate with the 10.92.2.xxx on Site 2? If yes, the you need to try my suggestion above.
DaneA
NETGEAR Community Team
