PeterBroersen
Feb 08, 2017Aspirant
SRX5308 VPN to FVS318v3
Does anybody know if it is possible to set up a VPN connection between a SRX5308 and a FVS318v3? I have succesfully connected 2 FVS318v3's with VPN, but now 1 of them needs to be replaced because th...
Dan_Z
Feb 08, 2017NETGEAR Expert
Hello,
Welcome to the community!
Here is the reference link:
http://kb.netgear.com/24278/Configuring-a-Box-to-Box-VPN-on-ProSAFE-ProSECURE-routers-using-the-VPN-Wizard
Thanks
- PeterBroersenFeb 09, 2017Aspirant
Hello Dan,
Thanks for your answer. But unfortunately: I already tried to use the wizard.
On the SRX5308 I see 'IPsec SA Not Established' on the Connection Status-tab.
And on the Monitoring-page on the tab 'VPN Logs':
Thu Feb 09 10:47:06 2017 (GMT +0100): [SRX5308] [IKE] ERROR: Phase 1 negotiation failed due to time up for 83.***.***.69[500]. 6cf7de814b79cabb:cdc28d9e092f42f8
Thu Feb 09 10:46:58 2017 (GMT +0100): [SRX5308] [IKE] ERROR: Ignore information because the message has no hash payload.
Thu Feb 09 10:46:52 2017 (GMT +0100): [SRX5308] [IKE] INFO: Received Malformed packet of payload length 12644 and total length 40.
Thu Feb 09 10:46:47 2017 (GMT +0100): [SRX5308] [IKE] INFO: Received Malformed packet of payload length 12644 and total length 40.
Thu Feb 09 10:46:42 2017 (GMT +0100): [SRX5308] [IKE] INFO: Received Malformed packet of payload length 12644 and total length 40.
Thu Feb 09 10:46:37 2017 (GMT +0100): [SRX5308] [IKE] ERROR: invalid ID payload.
Thu Feb 09 10:46:37 2017 (GMT +0100): [SRX5308] [IKE] WARNING: ID value mismatched.
Thu Feb 09 10:46:34 2017 (GMT +0100): [SRX5308] [IKE] INFO: Beginning Identity Protection mode.
Thu Feb 09 10:46:34 2017 (GMT +0100): [SRX5308] [IKE] INFO: Received request for new phase 1 negotiation: 192.168.178.51[500]<=>83.***.***.69[500]
Thu Feb 09 10:46:34 2017 (GMT +0100): [SRX5308] [IKE] INFO: Configuration found for 83.***.***.69[500].
Thu Feb 09 10:46:26 2017 (GMT +0100): [SRX5308] [IKE] ERROR: Phase 1 negotiation failed due to time up for 83.***.***.69[500]. 6d54b0ccf4b96a46:5db092d37e9b5e44
Thu Feb 09 10:46:18 2017 (GMT +0100): [SRX5308] [IKE] ERROR: Ignore information because the message has no hash payload.
Thu Feb 09 10:46:13 2017 (GMT +0100): [SRX5308] [IKE] INFO: Received Malformed packet of payload length 807 and total length 40.
Thu Feb 09 10:46:08 2017 (GMT +0100): [SRX5308] [IKE] INFO: Received Malformed packet of payload length 807 and total length 40.On the FVS318v3 VPN Status/Log:
[2017-02-09 11:43:26]<POLICY: VPN-GEIT> PAYLOADS: SA,PROP,TRANS,VID,VID
[2017-02-09 11:43:27]**** SENT OUT THIRD MESSAGE OF MAIN MODE ****
[2017-02-09 11:43:27]<POLICY: VPN-GEIT> PAYLOADS: KE,NONCE
[2017-02-09 11:43:27]**** RECEIVED FOURTH MESSAGE OF MAIN MODE ****
[2017-02-09 11:43:27]<POLICY: VPN-GEIT> PAYLOADS: KE,NONCE,VID
[2017-02-09 11:43:29]<ID PAYLOAD> Type = ID_IPV4_ADDR,ID Data=192.168.1.40
[2017-02-09 11:43:29]**** SENT OUT FIFTH MESSAGE OF MAIN MODE ****
[2017-02-09 11:43:37]**** RECEIVED SIXTH MESSAGE OF MAIN MODE ****
[2017-02-09 11:43:40]**** RECEIVED SIXTH MESSAGE OF MAIN MODE ****
[2017-02-09 11:43:44]**** RECEIVED SIXTH MESSAGE OF MAIN MODE ****
[2017-02-09 11:43:49]**** SENT OUT INFORMATIONAL EXCHANGE MESSAGE ****
[2017-02-09 11:43:49]<POLICY: VPN-GEIT> PAYLOADS: DEL
[2017-02-09 11:43:49][==== IKE PHASE 1(to 217.***.***.31) START (initiator) ====]
[2017-02-09 11:43:49]**** SENT OUT FIRST MESSAGE OF MAIN MODE ****
[2017-02-09 11:43:49]<POLICY: VPN-GEIT> PAYLOADS: SA,PROP,TRANS
[2017-02-09 11:43:49]**** RECEIVED SECOND MESSAGE OF MAIN MODE ****
[2017-02-09 11:43:49]<POLICY: VPN-GEIT> PAYLOADS: SA,PROP,TRANS,VID,VID
[2017-02-09 11:43:50]**** SENT OUT THIRD MESSAGE OF MAIN MODE ****
[2017-02-09 11:43:50]<POLICY: VPN-GEIT> PAYLOADS: KE,NONCE
[2017-02-09 11:43:50]**** RECEIVED FOURTH MESSAGE OF MAIN MODE ****
[2017-02-09 11:43:50]<POLICY: VPN-GEIT> PAYLOADS: KE,NONCE,VID
[2017-02-09 11:43:52]<ID PAYLOAD> Type = ID_IPV4_ADDR,ID Data=192.168.1.40
[2017-02-09 11:43:52]**** SENT OUT FIFTH MESSAGE OF MAIN MODE ****
[2017-02-09 11:43:57]**** RECEIVED SIXTH MESSAGE OF MAIN MODE ****
[2017-02-09 11:44:07]**** RECEIVED SIXTH MESSAGE OF MAIN MODE ****
[2017-02-09 11:44:12]**** SENT OUT INFORMATIONAL EXCHANGE MESSAGE ****
[2017-02-09 11:44:12]<POLICY: VPN-GEIT> PAYLOADS: DELI hope this helps to solve the problem.
Additional information: On the same side as the SRX5308, there is still an old FVS318v3. If I configure the VPN on this firewall, the VPN is up in no time...
- Dan_ZFeb 09, 2017NETGEAR Expert
Hi PeterBroersen,
I'm sorry, I clicked "Accept as Solution" accidentally.
Could you compare the parameters of IKE policy and VPN policy on two box? Make sure the all parameters is same except the ip address.Thanks,
Dan
Hello Dan,
I checked and double-checked all the settings, four times. Everything is exactly the same.
Do you want to see any screenprints of something?
