HenrikA
Feb 10, 2017Tutor
SRX5308. With BWP it getts slower and slower. Error: Failed to release class(76)
I have an SRX5308 running with Bandwidth Profiles; Guests and Office. When people connect to the wifi they automatically get an IP (above 100) with the bandwidth profile Guest that have a limited upl...
- Feb 26, 2017
Thanks for the update. I'm glad to know that the problem is not present when using an earlier version of the firmware. :) Just to be specific, what earlier firmware version of the SRX5308 make it work?
Since the problem is resolved for now using an earlier version of the firmware, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
NETGEAR Community Team
DaneA
Feb 13, 2017NETGEAR Employee Retired
Hi HenrikA,
I suggest you to update the firmware of the SRX5308 to the latest version 4.3.4-2 then perform a factory reset and reconfigure it from scratch. Then, check if same problem will occur. You can download the latest firmware v4.3.4-2 here.
For the logs to be analyzed, you may open an online case with NETGEAR Support at anytime. Let them know about your concern and attach the logs on the online case. It will be forwarded to the engineering team for it to be interpreted.
DaneA
