JB007Rules
Dec 30, 2014Aspirant
SRX5308 won't work with Shrew. FVS336G Works Perfectly!
Guys,
I cannot for the LIFE of me figure out why I can't get Shrew to work with the SRX5308 when I have it set up VERBATIM to what is HERE: https://www.shrew.net/support/Howto_Netgear
When I set this up VERBATIM on an FVS336G it works PERFECTLY FINE.
All routers have the latest firmware (4.3.1-22)
When testing on the FVS336G, I've also used the latest firmware too (4.3.1-18)
Thanks in advanced for any help you might have :)
Thanks!
Thanks!
1 Reply
- NhellieVirtuososome users are having issues with the -22 FW. Try using this older version,
http://www.downloads.netgear.com/files/GDC/SRX5308/srx5308_v4.3.0-19.zip
You may also try disabling the PFS on the router.
