jgrove
Dec 31, 2012Aspirant
SRXN 3205 WAN Speed Question
I have owned a SRX3205 for a number of years and it has worked flawlessly.
I will soon be increasing my WAN speed to 100mb D/l and 5-10 mb
Can anyone confirm if the router will support such speed?
My current cable supplier is set to 60mb but i am upgrading it too 100mb.
Thanks in advance,
Thanks in advance,
- aditMentorNo, 60Mbps, as listed in the specs.
- jgroveAspirantThanks for confirming that, any ideas what i can replace it with?
- jmizoguchiVirtuosohttp://www.netgear.com/service-provider/products/security/wireless-VPN-firewalls/SRXN3205.aspx
Throughput
LAN-to-WAN: 60 Mbps
Connections: 20,000 concurrent sessions
VPN throughput: 20 Mbps - jmizoguchiVirtuoso
jgrove wrote: Thanks for confirming that, any ideas what i can replace it with?
look other model under spec!!!!
Prosafe is limited on wifi so you need to buy prosafe wired router and add AP or below
http://prosecure.netgear.com/products/prosecure-utm-series/models.php
UTM9S for built-in wifi. CLICK ON COMPARE ALL UTM MODELS AT BOTTOM LEFT - aditMentorUTM25s is out as well.
