H3llGhost
Oct 08, 2011Aspirant
SRXN3205 No internet for any clients
Hello, I am facing the problem, that my clients losing the internet access after a short time. The WAN Status is always connected and I can lookup all domains, but I don't get any data to my clie...
Daedalus01
Oct 09, 2011Aspirant
He means Class A ip range June. I also hope your going Classless, as that may be throwing the router into a UDP flood as Class A classful subnet has a possible 16 million hosts. Have you factory reset the unit and see if it functions straight out of the box? Its one way for sure to know if the router is malfunctioning, or if a setting that you applied is causing the glitch.
