H3llGhost
Oct 08, 2011Aspirant
SRXN3205 No internet for any clients
Hello, I am facing the problem, that my clients losing the internet access after a short time. The WAN Status is always connected and I can lookup all domains, but I don't get any data to my clie...
H3llGhost
Oct 09, 2011Aspirant
Daedalus01 wrote: [...]Have you factory reset the unit and see if it functions straight out of the box? Its one way for sure to know if the router is malfunctioning, or if a setting that you applied is causing the glitch.
Yes I did a factory reset and tried again with the internet and all worked. :)
