dysonp
Nov 27, 2012Aspirant
srxn3205 port forwarding
I am trying to connect to my mac server(mountain lion) via VPN using L2TP. On the SRXN3205, I have set up services for UDP ports 1701 and 4500 and under "Firewall", I have forwarded these ports to th...
dysonp
I have done some further investigation of the problem and when I try to connect to the mac VPN server, the router logs say:
I have VPN pass through ticket for IPsec, PPTP and L2TP. Has anyone else encountered this problem?
2012 Nov 27 17:00:37 [SRXN3205] [IKE] Could not find configuration for xxx.xx.xx.xxx[500]_
2012 Nov 27 17:00:37 [SRXN3205] [kernel] LOG_PACKET[ACCEPT] IN=WAN OUT=SELF SRC=xxx.xx.xxx.xxx DST=xxx.xxx.xx.xx PROTO=UDP SPT=500 DPT=500
