dysonp
Nov 27, 2012Aspirant
srxn3205 port forwarding
I am trying to connect to my mac server(mountain lion) via VPN using L2TP. On the SRXN3205, I have set up services for UDP ports 1701 and 4500 and under "Firewall", I have forwarded these ports to th...
OHPRSTech
Jan 18, 2013Aspirant
Hey, thanks, I got it working. The problem had nothing to do with my firewall settings. I had transposed a couple of digits in the gateway IP. After that, it worked. All the ports did forward to my target LAN address, no problem. I did not have to specify each desired port for this to work. After testing this, I did specify the ports I wanted: SMTP, DNS, HTTP, HTTPS, and it worked fine. What was nice it that port I did not specify were, in fact, blocked. With the Cisco RVS4000, I had to specify an additional rule as last priority denying access on ANY port. Otherwise, non-specified ports got through anyway. The Netgear behavior is much more desirable.
Thanks again:):)
Thanks again:):)
