eiwoh
Oct 11, 2011Novice
SRXN3205 SSL VPN will not communicate with remote PCs
I have an SRXN3205 with an SSL VPN setup. The VPN has been setup for a while with no problems until now. At least I'm just noticing it now. Last time I tried was about two months ago. Now when I conn...
eiwoh
Oct 12, 2011Novice
Not as far as I can tell. I did x out my username, but the rest is untouched. This is the only message that is in the SSL VPN log. Just repeats it a couple of times. The Firewall Log just show users connecting. Neither show any errors.
2011 Oct 11 19:48:57 [SRXN3205] [sslvpntunnel] id=SRXN3205 time="2011-10-11 19:48:57" fw=howieland.homeserver.com pri=6 rule=access-policy proto="SSL VPN Tunnel" src=76.10.240.8 user=xxx dst=howieland.homeserver.com arg="" op="" result="" rcvd="" msg="SSL VPN Tunnel"
