eiwoh
Oct 11, 2011Novice
SRXN3205 SSL VPN will not communicate with remote PCs
I have an SRXN3205 with an SSL VPN setup. The VPN has been setup for a while with no problems until now. At least I'm just noticing it now. Last time I tried was about two months ago. Now when I conn...
jmizoguchi
Oct 12, 2011Virtuoso
Now when I connect to the VPN I can not access my remote systems, no pings, ssh etc... I have it enabled for a full tunnel. If I setup a split tunnel than I can access the remote machines. But only that traffic is being passed throught the VPN. Any ideas?
sounds like setting went screwy..
have you delete the SSL-VPN portal setting and make new one?
full tunnel failure means some how DNS is properly not working with client to to pass internet traffic but should still able to pass tunnel traffic but been very small setting in the portal settings, I suggest to delete and recreate might just as quick diagnostic then just looking at log
