eiwoh
Oct 11, 2011Novice
SRXN3205 SSL VPN will not communicate with remote PCs
I have an SRXN3205 with an SSL VPN setup. The VPN has been setup for a while with no problems until now. At least I'm just noticing it now. Last time I tried was about two months ago. Now when I conn...
eiwoh
Oct 12, 2011Novice
jmizoguchi wrote: sounds like setting went screwy..
have you delete the SSL-VPN portal setting and make new one?
full tunnel failure means some how DNS is properly not working with client to to pass internet traffic but should still able to pass tunnel traffic but been very small setting in the portal settings, I suggest to delete and recreate might just as quick diagnostic then just looking at log
Yes I have deleted all the settings several times. I have rebooted it a couple of times. I'm not home right now so I can't power cycle it. I have been using teamviewer on a client to troubleshoot. When I set it to spit tunnel I can access my remote systems without configuring any client routes, but only that traffic to my remote machines is going through the VPN. In full tunnel all traffic goes through the VPN properly but I can't access my remote systems.
I guess when I get home I'll have to reset the unit and start fresh unless I find that screwed up setting. I haven't changed anything and it worked last July. Thanks.
