eiwoh
Oct 11, 2011Novice
SRXN3205 SSL VPN will not communicate with remote PCs
I have an SRXN3205 with an SSL VPN setup. The VPN has been setup for a while with no problems until now. At least I'm just noticing it now. Last time I tried was about two months ago. Now when I conn...
eiwoh
Oct 16, 2011Novice
It turns out there is nothing wrong with the settings on my SRXN3205. I had a friend try and he was able to ping my remotes systems. I then set up a virtual machine and can access all my remote systems. So the problem is on my laptop. I've tried disabling antivirus and firewall. But that didn't help. Checked for system updates and noticed my laptop is giving an error and unable to get updates. Ran a full system virus scan and checked with Malwarebytes just to be sure. System is clean, but has something wrong preventing me from getting updates.
