rdsn
Jul 23, 2014Aspirant
SSL Endpoint UTM150
Hi I am trying to have a UTM150 act as an endpoint for an imcoming HTTPS site. ie Client -> UTM150 -> WebServer |------SSL-----------||-----HTTP-----| I have a number of existing SSL certificate...
adit
Jul 24, 2014Mentor
Are you trying to use the cert for SSL VPN or just for the webserver? Is the website public or private? The UTM can use that cert for SSL VPN/Remote Management. It is only a HTTPS (using 443) endpoint when Remote Management is left on the default port of 443 (most switch it to a port in the 8000-8100 range).
rdsn wrote: So the UTM will not act as an endpoint for https/SSL then? Very strange design as it is marketed as a enterprise product. :confused: Thanks for your reply
