lordarpad
Sep 17, 2011Aspirant
syslog logging through VPN tunnel
Hi I have a FVS 336G tunneling with a fvx338. Both are configured to write their logs to a linux box in the LAN of rthe FVS336G. the FVS336G does this without problem. I am not seeing hide nor hair...
Markwirez
Nov 11, 2011Aspirant
As long as you have your logging level and specific options set correctly AND your site to site VPN prefixes setup AND connected you should see things showing up. Your Far Side Router may be trying to send the traffic with a source IP address of the WAN interface there for routing to the internet instead of across the tunnel.
All else fails create an inbound service rule on the one router and forward your syslog to the public IP interface.
One thing to do with this as well is setup the Local identifier under the Firewall Logs & Email tab under monitoring. Do the same thing under Administration--> SNMP -->SNMP System Info.
