ratherman
Apr 21, 2017Guide
WAC720 syslog - set logging level
I setup sysloglogging on my ensemble - problem is, is that it is filling my logs with - "Ensemble matching Behavior between ..." - severity 1. I have (4) units setup in an ensemble and I get these every couple of seconds. These should not be severity 1 (Alert) - I would think that is informational.
Yes those messages are informational. We have made some enhancement in the next relase ( early May )which will supress these logs.
Thanks
Raghu
- RaghuHRNETGEAR Expert
Thanks
Raghu
Just installed firmware 3.7.10.0 and it appears to fix that - thanks...
