redtech116's avatar
redtech116
WAC720 LOCKING UP
Having a radom lockup issue...on two different wac720 units at different sites
the wireless just stops, can not log into the unit,
disconnect/reconnect ethernet has no effect.
Have to power cycle the units for them to come back..
using the current firmware.
one unit on POE another using an AC power adpter...
have reset and resetup the unit once already.
logs for one after rebooting..
[Jan 28 2017 19:20:08] [info] hostapd[1352] STA 18:a6:f7:94:87:f8 associated with BSSID 2c:30:33:08:a4:20
[Jan 28 2017 19:20:08] [info] hostapd[1352] Assoc request from 18:a6:f7:94:87:f8 BSSID 2c:30:33:08:a4:20 SSID Hell-Fire-69
[Jan 28 2017 19:19:51] [err] mDNSResponder mDNSPlatformRawTime went backwards by 51998735 ticks; setting correction factor to 954928979
[May 31 2016 16:00:49] [warn] dman[1107] DHCP-client: Interface brtrunk obtained lease on new address 192.168.1.103.
[May 31 2016 16:00:49] [info] hostapd[1352] Send failed (to server 192.168.1.1) - maybe interface status changed - try to connect again
[May 31 2016 16:00:45] [info] hostapd[1352] Send failed (to server 192.168.1.1) - maybe interface status changed - try to connect again
[May 31 2016 16:00:44] [info] hostapd[1352] Send failed (to server 192.168.1.1) - maybe interface status changed - try to connect again
[May 31 2016 16:00:43] [info] hostapd[1352] Send failed (to server 192.168.1.1) - maybe interface status changed - try to connect again
[May 31 2016 16:00:42] [info] hostapd[1352] Send failed (to server 192.168.1.1) - maybe interface status changed - try to connect again
[May 31 2016 16:00:40] [info] hostapd[1352] Send failed (to server 192.168.1.1) - maybe interface status changed - try to connect again
[May 31 2016 16:00:40] [info] hostapd[1352] STA 48:a1:95:cc:78:dd associated with BSSID 2c:30:33:08:a4:20
[May 31 2016 16:00:40] [info] hostapd[1352] Assoc request from 48:a1:95:cc:78:dd BSSID 2c:30:33:08:a4:20 SSID Hell-Fire-69
[May 31 2016 16:00:40] [err] hostapd[1352] trying to deauthenticate to station 48:a1:95:cc:78:dd, but not authenticated
[May 31 2016 16:00:40] [err] hostapd[1352] trying to update accounting statistics, station 48:a1:95:cc:78:dd not found
[May 31 2016 16:00:40] [info] hostapd[1352] STA 48:a1:95:cc:78:dd deauthed from BSSID 2c:30:33:08:a4:20 reason 3: STA is leaving IBSS or ESS
[May 31 2016 16:00:39] [info] hostapd[1352] Send failed (to server 192.168.1.1) - maybe interface status changed - try to connect again
[May 31 2016 16:00:38] [info] hostapd[1352] Send failed (to server 192.168.1.1) - maybe interface status changed - try to connect again
[May 31 2016 16:00:36] [info] hostapd[1352] Send failed (to server 192.168.1.1) - maybe interface status changed - try to connect again
[May 31 2016 16:00:36] [info] hostapd[1352] STA d8:49:2f:26:2b:e1 associated with BSSID 2c:30:33:08:a4:20
[May 31 2016 16:00:36] [info] hostapd[1352] Assoc request from d8:49:2f:26:2b:e1 BSSID 2c:30:33:08:a4:20 SSID Hell-Fire-69
[May 31 2016 16:00:35] [info] hostapd[1352] Send failed (to server 192.168.1.1) - maybe interface status changed - try to connect again
[May 31 2016 16:00:35] [debug] hostapd[1352] station: 48:a1:95:cc:78:dd deauthenticated
[May 31 2016 16:00:35] [info] hostapd[1352] STA 48:a1:95:cc:78:dd disassociated from BSSID 2c:30:33:08:a4:20 reason 8: Sending STA is leaving BSS
[May 31 2016 16:00:30] [info] hostapd[1352] Send failed (to server 192.168.1.1) - maybe interface status changed - try to connect again
[May 31 2016 16:00:24] [info] hostapd[1352] Send failed (to server 192.168.1.1) - maybe interface status changed - try to connect again
[May 31 2016 16:00:21] [info] hostapd[1352] Send failed (to server 192.168.1.1) - maybe interface status changed - try to connect again
[May 31 2016 16:00:21] [info] hostapd[1352] STA 48:a1:95:cc:78:dd associated with BSSID 2c:30:33:08:a4:20
[May 31 2016 16:00:21] [info] hostapd[1352] Assoc request from 48:a1:95:cc:78:dd BSSID 2c:30:33:08:a4:20 SSID Hell-Fire-69
[May 31 2016 16:00:18] [info] dman[1107] SSL certificate generated for Clusterd
[May 31 2016 16:00:16] [info] hostapd[1352] STA d8:49:2f:26:2b:e1 associated with BSSID 2c:30:33:08:a4:20
[May 31 2016 16:00:16] [info] hostapd[1352] Assoc request from d8:49:2f:26:2b:e1 BSSID 2c:30:33:08:a4:20 SSID Hell-Fire-69
  • RaghuHR's avatar
    RaghuHR
    May 04, 2017
    All
    We have addressed this issue in the latest firmware. Please download here.
    Thanks
    Raghu
ProSupport for Business
