redtech116
Jan 28, 2017Aspirant
WAC720 LOCKING UP
Having a radom lockup issue...on two different wac720 units at different sites the wireless just stops, can not log into the unit, disconnect/reconnect ethernet has no effect. Have to power cycle ...
TylerSmelley
Mar 27, 2017Aspirant
I'm having the exact same issue. I have three WAC720's behind a Netgear Prosafe Managed Switch. The AP's were installed winter 2015 and had no issues until December 2016. A single AP will lock up, all LED's are steadily lit, cannot ping the AP, only a hard power cycle resolves the issue. I've updated all AP's to the latest firmware, this did not resolve the issue. I have replaced one of the AP's no resolution. All have been factory reset and re-configured multiple times. No other issue on the network at all.
Has anyone rolled back to an earlier firmware with any success?
- RaghuHRMar 27, 2017NETGEAR Expert
Hi TylerSmelly,
Very sorry to hear your issues. We are actively working on this issue. Could you please let us know the following details ?
- Could you please send this CLI command out put?
bootenv -d pmon_ver
- How many wireless clients connected to WAC720? Need model details
- Are you trying to connect 2.4 Ghz or 5 Ghz radio?
- Does this issue happens on 2.4Ghz or 5 Ghz radio?
- Have you enabled captive portal or not?
- Are you using AP in standalone mode or configured for ensemble?
- Are you seeing any random AP reboots or just hang?
- What kind of traffic or application are you running on the wireless clients?
- Do you have the console connection so that we can have live debug when the issue happens.
Thanks
Raghu
