knarfer
Apr 13, 2018Aspirant
Wac720 blinking led
Hi,
i have a AP wac720 with a orange blinking led. normaly this AP is connected to a wireless controller.
it is not possible to connect to the ip address so i connect with a serial cable.
when the AP startup i can see messages like "Bad Eraseblock ..."
i try to upgrade the firmware to standalone version with tftp. then i receive the message network is unreachable.
is it possible to upgrade the firmware other than over network?
regards
frank
Hi knarfer,
It seems that you need to perform recovery steps to the WAC720 access point. A fellow community member shared the steps in the forum thread below. Kindly follow the steps indicated and let us know the result. :)
Recovering WAC720/WAC730 access point via the console port
DaneA
NETGEAR Community Team
- DaneANETGEAR Employee Retired
Hi knarfer,
DaneA
NETGEAR Community Team - DaneANETGEAR Employee Retired
I just want to follow-up on this. Were you able to perform the steps from the forum thread I shared? If yes, what is the result?
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
- knarferAspirant
Hi Dane,
that was the solution.
i perform the steps in the document and the ap works again.
Thanks for the support
regards
Knarfer
