Firmware
113 TopicsWAX610 – 802.1X Supplicant on Wired Uplink Port – Feature Availability
Hello NETGEAR Support Team, I am currently deploying a network infrastructure using several WAX610/WAX620 access points (firmware up to date) combined with a MS510TXPP managed switch. As part of my security architecture, I would like to enable 802.1X port authentication on the switch ports connected to the access points, in order to prevent unauthorized access in the event an AP is physically removed and replaced by a rogue device. This requires the WAX610 to act as an 802.1X supplicant on its wired uplink/LAN port — independently from the 802.1X authenticator role it already plays for wireless clients via RADIUS. After reviewing the WAX610 user manual thoroughly, I could not find any mention of this capability on the wired port. My questions are: Does the WAX610 currently support 802.1X supplicant functionality on its wired uplink port? If not, is this feature on the roadmap for a future firmware release? This is a fairly standard enterprise security requirement, and I believe many customers deploying WAX610 in environments where physical security of the AP cannot be fully guaranteed would benefit from it. Thank you for your time and assistance. Best regards78Views0likes1CommentWAX630E v12.8.0.6 log messages
I’m hoping someone from Netgear support can pass this along to engineering. Since updating my multiple WAX630E access points to firmware version V12.8.0.6, all of them are continuously displaying the following messages in the system log files. New messages are generated about every second. May 3 09:26:44 nddmp[5641]: nddmp total time to execute = 1.000000 seconds May 3 09:26:43 nddmp[5641]: NDDMP: data received from lighttpd = "[REMOVED]" May 3 09:26:43 nddmp[5641]: nddmp total time to execute = 0.000000 seconds May 3 09:26:43 nddmp[5641]: NDDMP: data received from lighttpd = "[REMOVED]" May 3 09:26:43 nddmp[5641]: nddmp total time to execute = 1.000000 seconds May 3 09:26:42 nddmp[5641]: NDDMP: data received from lighttpd = "[REMOVED]" May 3 09:26:30 root: monitor_stuck is running May 3 09:26:14 root: monitor_stuck is running May 3 09:25:58 root: monitor_stuck is running May 3 09:25:42 root: monitor_stuck is running207Views0likes1CommentWAX630 continuous reboot loop: dvlan_fallback=1 firmware bug (hostapd_tr SIGABRT)
Hardware: WAX630, firmware 12.5.0.15, managed via Netgear Insight My WAX630 has been crashing and rebooting every 15–20 minutes for months, and after digging through the AP's own diagnostic logs I've pinpointed the root cause. Sharing here in case anyone else hits this and hoping someone has found a workaround I haven't tried yet. What's happening After every reboot, the crash repeats on the same ~17-minute cycle: hostapd_tr crashes with SIGABRT (signal 6) → configd loses IPC connection → nddmp database timeouts → apmonitord watchdog fires ("confd_stuck_handler: No response from configd") → AP reboots → repeat The AP's own `/etc/sysconfiglog/log/` directory has three `core.hostapd_tr.*.tar` crash dumps spanning March 2025 through July 2025, all with the same signal-6 signature, so this has been happening across multiple firmware versions (V10.8.12.9 and V10.8.13.2, and now current 12.5.0.15). Root cause (from the logs) The firmware config generator is writing `dvlan_fallback=1` on every VAP even though Dynamic VLAN (`dvlan_status`) is `0` (disabled) on every SSID. That contradiction means hostapd tries to open an L2 packet interface on the VLAN bridge (`br-lan`) for each VAP on every boot, and fails. Every boot produces 193 occurrences of this error in `hostapd.txt`: Failed to open l2_packet interface for vlan bridge Those failures flood hostapd_tr until it hits an unrecoverable state and aborts. The fix is straightforward: set `dvlan_fallback=0` on all VAPs. But `dvlan_fallback` isn't exposed anywhere in the Insight UI, and SSH is locked to Netgear engineering on Insight-managed APs, so there's no way for an end user to push that change directly. Proof it's WAX630-specific, not a config issue I compared against a WAX610Y at the same Insight location receiving the identical config push: WAX630 WAX610Y `dvlan_fallback` value 1 1 - identical `dvlan_status` value 0 0 - identical l2_packet errors per boot 193 0 hostapd_tr core dumps 3 confirmed 0 Crash frequency Every ~17 min Never Continuous uptime ~14 min 5h 41 min Same Insight account, same location, same SSIDs, same config, zero errors on the WAX610Y, constant crashes on the WAX630. This is a WAX630-specific hostapd behavior, not a network or config mistake on my end from what I can tell. What I've already tried (all failed to fix dvlan_fallback) Toggling VLAN IDs (1 → 2 → 1) on all SSIDs via Insight Enabling WPA2 Enterprise + Dynamic VLAN on a test SSID, then disabling `dvlan_fallback` still written as `1` SSH resets at KEXINIT, confirmed blocked for end users on Insight-managed APs Factory reset + re-adoption, reset firmware on the device to pick up net-new configuration from Insight, but since `dvlan_fallback=1` is written by the config generator on every Insight push, it reproduces the same config Temporary stability workaround (not a fix) I stabilized the AP by removing the secondary crash trigger: a client device was connecting at -88 dBm RSSI in a rapid 802.11r roaming loop, creating additional hostapd churn on top of the dvlan_fallback stress. Changes applied via Insight: Disabled 802.11r (Fast Roaming) location-wide Enabled Load Balancing → Balance on Client Rx RSSI (value 23 ≈ -72 dBm threshold) Enabled Disassociate Sticky Clients (2.4GHz: -70 dBm, 5GHz: -80 dBm, 6GHz: -78 dBm) After these changes: 12+ hours continuous uptime, zero l2_packet errors on current boot. But `dvlan_fallback=1` is still in the config; this is a bandage, not a fix. If hostapd stress increases for any reason, the underlying bug will reassert. Netgear's own 12.5.0.15 release notes list "Hostapd interface wifixvapx is unresponsive" as a known open issue. This appears to be the specific config path (dvlan_fallback=1 + dvlan_status=0) that triggers it. What I'm looking for Has anyone found a way to force `dvlan_fallback=0` through the Insight UI (or any other end-user-accessible method)? Has anyone had Netgear support successfully push a remote config fix for this? Is anyone else seeing this same crash pattern on WAX630? Would be helpful to know if this is widespread. I have detailed logs including three device-generated core dumps and before/after comparisons if anyone from Netgear engineering wants to look. Happy to share. Firmware: 12.5.0.15 | Management: Insight | Crash signal: SIGABRT (6) | Affected process: hostapd_tr287Views0likes1CommentFW page shows 'Updates Available'
Experiencing the same thing with WBE750 APs. Notification that FW updates are available went out and the FW page shows 'Updates Available' in some icons, but when you attempt to 'update' it just says you are on the latest version already (it's not). The manual files are not available on the downloads page either, so it's not possible to do it through the local interface. Forcing a factory reset and starting the device up from new also does not appear to make a difference (ask me how I know). Hoping this gets sorted out within a couple of days1.1KViews1like13CommentsWAX610 firmware version 12.5.0.15
The download for the WAX610 firmware version 12.5.0.15 contains a TAR file within the TAR file so the upgrade does not recognise it. I got it to work by unzipping the inner TAR file but you might want to replace the file so other users don't need to do this.Solved578Views0likes2CommentsWAX625 | No firmware 12.5.0.12 inside Netgear Insight list
Hi, On Jan 6, 2026, 10:02 PM PT, I received alert from Netgear Insight Alert (via e-mail) that new firmware is available: WAX625/WAX628 Firmware Version 12.5.0.12 I am interested in installing this firmware as it supposedly fixes issues with random reboots and I was experiencing something similar where device just locks itself and all SSIDs become unavailable and the only remedy was power restart. Those power restarts are not trivial for me because WAP is PoE powered and high up on the wall. I was forced to buy a timer which cuts out power to the whole network rack including main router (fw) and WAX625. I went into the Netgear Insight > Firmware > Set Target Firmware (upper right corner) to find this firmware 12.5.0.12 and it is not on the list. The latest I see is 11.8.0.9 which appears to be also the one I have installed and the latest one listed on the product page: https://www.netgear.com/support/product/wax625 So, I am wondering what is going on here? Why did I get this e-mail when the firmware is not generally available for install? Thank you!1.9KViews6likes13CommentsNetgear WiFi 7 WBE710 802.11k/v Disabled After FW upgrade.
I upgraded to V11.8.0.14 and I'm not seeing on my devices that 802.11k/v are now disabled. I know 802.11r is only supported with InSights but now they are disabling features? I rolled back to V11.5.1.5 and then they show enabled. Why is Netgear disabling features for APs? Is anyone else seeing the same? You can't even open a support case with Netgear without paying nowadays. This are extremely useful protocols for device roaming and now they are disabled in the backend? I would like an explanation. Factory reset performed made no difference. Quick Configuration Settings - Everything else is default. Static LAN IP Configured 192.168.x.x SystemName Set LED Disabled - High doubt it is this. I've seen weirder Single SSID Configured WPA3/WPA2 Personal VLAN ID configured Band Steering Enabled Wireless Settings - 2.4/5/6Ghz All 3 bands are configured with Dynamic Channel Width367Views0likes0CommentsInsight offering Updates already in place?
Dear Pramendra What is going on in the Insight platform? Strange to see update proposals for devices with certainly the latest firmware in place already? Insight does list any Netgear device, including many not supported by Insight? TIA, -Kurt.403Views0likes6Comments
