DTCtechie303
Dec 27, 2025Follower
Netgear WiFi 7 WBE710 802.11k/v Disabled After FW upgrade.
I upgraded to V11.8.0.14 and I'm not seeing on my devices that 802.11k/v are now disabled. I know 802.11r is only supported with InSights but now they are disabling features? I rolled back to V11.5.1.5 and then they show enabled. Why is Netgear disabling features for APs? Is anyone else seeing the same? You can't even open a support case with Netgear without paying nowadays. This are extremely useful protocols for device roaming and now they are disabled in the backend? I would like an explanation.
Factory reset performed made no difference.
Quick Configuration Settings - Everything else is default.
Static LAN IP Configured 192.168.x.x
SystemName Set
LED Disabled - High doubt it is this. I've seen weirder
Single SSID Configured
WPA3/WPA2 Personal
VLAN ID configured
Band Steering Enabled
Wireless Settings - 2.4/5/6Ghz
All 3 bands are configured with Dynamic Channel Width
No RepliesBe the first to reply
