JrBK
Aug 27, 2022Aspirant
WAC720 and WAC730
Does anyone have experience using the WAC720 and WAC730 in the same ensemble? Will it work successfully? Any recommendations and comments are welcome.
Thank you.
Hi JrBK,
Yes, it should work (you may refer to page 87 of the user manual here under Set Up, Manage, and Monitor Ensembles).
As for configuring it, you may check these resources as well:
NETGEAR ProSAFE WAC720 and WAC730 How to Create an Ensemble
How to Create an Ensemble with Two WAC720 or WAC730
JeraldM
NETGEAR Community Team
- JeraldMNETGEAR Employee Retired
Hi JrBK,
JeraldM
- JrBKAspirant
Thank you JeraldM! I appreciate you leading me to the right place. There was one publication that I found (by Netgear) that said they should not be combined in one Ensemble. That must have been a very early publication. The manual was very helpful and I now have all six (three 720 and three 730) in one ensemble and they seem to be working as they should.
