redtech116
Jan 28, 2017Aspirant
WAC720 LOCKING UP
Having a radom lockup issue...on two different wac720 units at different sites the wireless just stops, can not log into the unit, disconnect/reconnect ethernet has no effect. Have to power cycle ...
RaghuHR
Jan 29, 2017NETGEAR Expert
Hi redtech116
Sorry to hear this issue. Could you please share the following to understand more ?
- How many wireless clients are trying to connect WAC720 AP?
- Are you seeing issue on 2.4Ghz radio or 5 Ghz or both?
- Is it possible to share wireless client details? ( Is it mobile devices or laptops? share model details)
- Share those logs before you do AP reboot
- I guess you are using latest firmware 3.6.12.0
- WAC720 AP configuration file
Thanks
Raghu
redtech116
Jan 31, 2017Aspirant
- How many wireless clients are trying to connect WAC720 AP? between 0 and 4 at this site
- Are you seeing issue on 2.4Ghz radio or 5 Ghz or both? the whole AP locks up..no throughput on anything
- Is it possible to share wireless client details? ( Is it mobile devices or laptops? share model details) 1-iphone / 1 - mac / 1 - windows 10 PC / 1 - android phone
- Share those logs before you do AP reboot? i don't have a remote syslog server setup yet / so all longs are kinda lost after reboot
- I guess you are using latest firmware 3.6.12.0 / yes
- WAC720 AP configuration file / will post later tonight
- RaghuHRFeb 01, 2017NETGEAR Expert
Hi redtech116
Thanks for the info, It would be nice if you mention the model of those wireless clients ( Windows, iphones, andriod and macs) ? Are you connecting these clients to 2.4 G radio or 5 Gh?
Please attach the AP confg as well. Logs would help more if you can attach if you have taken during issue.
Thanks again
Raghu
- redtech116Feb 01, 2017Aspirant
why can I not attach a file here...? I can attach a picture but not a file..come on NETGEAR
the AP completely locks up , can not log into it wirelessly or wired...
some are on the 5 some are on the 2.4 radio's..take your pick..
this is about all i can give anyone..
https://www.dropbox.com/s/40z7qcprc0g7rlo/config.xml?dl=0
- DCMDataMar 07, 2017Tutor
I would like to get in on this, I am having the exact same issue. All the lights stay on but it kicks everything off. We have 1 garage door opener, 3 asus laptops, 2 android phones, a ring door bell, and ring door bell speaker and that is it.
I also thought it was a hardware issue so Netgear replaced mine, got the new one programmed and same issue started again.
