Installation
107 TopicsWAX610 Ceiling Install
I DO see how to ceiling mount the ceiling base plate provided for this install... I do NOT see is where to drill the 2 anchor holes RELATIVE TO the PoE cable ceiling penetration point. Perhaps, a paper template would help. I just don't want the PoE cable to be visible after i slide/snap the WAX610 into place on the ceiling.56Views0likes4CommentsHelp understanding the "Set the 802.1Q VLAN and management VLAN" WBE750
On my router I have a X550 interface tagged with a vlan ID of "4" which attaches to my switch port as a "trunk port with a vlan id of "4"" on the switch I have an "access Port with a vlan id of "4" that is connected to my "WBE750" RJ45. In the LAN settings of the WBE750 Do I place the vlan id of 4 in the "Untagged VLAN" setting or the "Managed VLAN" setting. Any assistance would be greatly appreciated. Best Regards263Views0likes4CommentsWAX625 | No firmware 12.5.0.12 inside Netgear Insight list
Hi, On Jan 6, 2026, 10:02 PM PT, I received alert from Netgear Insight Alert (via e-mail) that new firmware is available: WAX625/WAX628 Firmware Version 12.5.0.12 I am interested in installing this firmware as it supposedly fixes issues with random reboots and I was experiencing something similar where device just locks itself and all SSIDs become unavailable and the only remedy was power restart. Those power restarts are not trivial for me because WAP is PoE powered and high up on the wall. I was forced to buy a timer which cuts out power to the whole network rack including main router (fw) and WAX625. I went into the Netgear Insight > Firmware > Set Target Firmware (upper right corner) to find this firmware 12.5.0.12 and it is not on the list. The latest I see is 11.8.0.9 which appears to be also the one I have installed and the latest one listed on the product page: https://www.netgear.com/support/product/wax625 So, I am wondering what is going on here? Why did I get this e-mail when the firmware is not generally available for install? Thank you!1.4KViews6likes13CommentsWAX615 Mehrere APs als quasi Mesh nutzen
Hallo Zusammen, ich habe zwei WAX615 APs und möchte dies noch um einen dritten evtl. sogar vierten erweitern um bspw. die verschiedenen Ebenen/Bereiche einer Immobilie abzudecken: AP1 = Paterre AP2 = Garage AP3 = Garten AP4 = 1. Stock Genutzt werden drei verschiedene SSIDs und Einstellungen: SSID mit nur 5GHz Sendekanal für AP1 40/5,2 GHz Sendekanal für AP2 48/5,24GHz PMF 802.11w optional Band Steering / 802.11 k/v aktiviert SSID mit nur 2,4GHz (Auto Kanal einstellung) PMF 802.11w optional Band Steering / 802.11 k/v aktiviert Gast-SSID mit beiden Frequenzen PMF 802.11w optional Band Steering / 802.11 k/v deaktiviert Allgemein Einstellungen: QoS ist für alle Frequenzen mit WMM und WMM Powersave aktiviert Spannung Tree Protocol aktiviert Network Integrity Check aktiviert IGMP Snooping deaktiviert Ethernet LLDP aktiviert UPnP aktiviert Powersetting 802.3at Load Balancing aktiviert Force Sticky Client ti disassociate deaktiviert Leider war die Anleitung da für mich nicht sehr hilfreich, daher wäre meine Frage: Was wäre die optimalen Einstellungen um die selben SSIDs auf allen APs quasi wie ein Mesh zu benutzen ohne die Insight App zu nutzen und Lokal zu konfigurieren? Viele Grüße und ein schönes verlängertes Wochenende460Views0likes6CommentsWAX615 Neighbor AP List
Hallo Zusammen, ich habe das Problem, dass ich zwei WAX615 an einem Netgear POE+ Switch ohne Insight sondern Lokal konfiguriert im gebrauch. Mesh kann ich nicht nutzen weil ich diese lieber Lokal konfigurieren möchte und es nicht einsehe dafür noch mal extra Geld zu zahlen (Finde ich persönlich schon eine Abzocke nur für Mesh Aktivierung extra Insight zu verwenden obwohl die APs schon teuer genug sind). Genutzt werden drei verschiedene SSIDs und Einstellungen: SSID mit nur 5GHz Sendekanal für AP1 40/5,2 GHz Sendekanal für AP2 48/5,24GHz PMF 802.11w optional Band Steering / 802.11 k/v aktiviert SSID mit nur 2,4GHz (Auto Kanal einstellung) PMF 802.11w optional Band Steering / 802.11 k/v aktiviert Gast-SSID mit beiden Frequenzen PMF 802.11w optional Band Steering / 802.11 k/v deaktiviert Allgemein Einstellungen: QoS ist für alle Frequenzen mit WMM und WMM Powersave aktiviert Spannung Tree Protocol aktiviert Network Integrity Check aktiviert IGMP Snooping deaktiviert Ethernet LLDP aktiviert UPnP aktiviert Powersetting 802.3at Load Balancing aktiviert Force Sticky Client ti disassociate deaktiviert Wenn ich die Neighbor AP Erkennung einschalte, sehen diese beiden sich nicht. Die EEM Funktin hatte ich schon abgeschaltet und dennoch erkennen, die beiden sich nicht und tauchen auch nicht auf der Unknown AP oder der Known AP Liste auf und ich würde die EEM Funktion eingentlich schon gern nutzen um Strom zu sparen. Komischerweise auf der Monitoring Systemseite wird als LLDP NAchbar der jeweilige WAX angezeigt. Also wollte ich die Liste in einer Textdatei selbst erstellen, alleridngs hilft die Sampledatei nicht weiter. Wenn ich die APs so eintrage, kann die Datei vom AP nicht übernommen werden. Die Anleitung hilft da nicht weiter, daher ein paar Fragen: Wie könnte ich die Liste erstellen, so dass ich weiß das die Struktur auf jeden Fall in Ordnung ist? Hat jemand eine passende und funktionierende Vorlage? An welcher Einstellung könnte es liegen, dass die zwei APs sich nicht erkennen? Viele Grüße und ein schönes verlängertes Wochenende192Views0likes1CommentNETGEAR WAX610 Dual-Band WiFi 6 Access Point
Hi. I want to create a local network that allows my devices to communicate directly with each other without having an internet connection. This way, I can use a master/slave app during band rehearsals/gigs even when I'm offline. Can you tell me what changes I have to make to the access point to configure it to work in this mode? Thanking you in advance. i’m a novice, so easy to understand instructions would be most helpful. Thank You!359Views0likes15CommentsWireless IP address switching
I want to install eight WAX630E access points (APs) in a large warehouse. All APs will be hardwired on Cat 6 back to a gigabit switch that has a 2.5 Gb uplinked to a cable modem connected to the internet via Comcast. A typical user will be most often work at one location in the warehouse. On occasion they will move to another area in the warehouse and be closer to a different AP. Do they keep the original ip address or will the closer AP which provides better signal strength and throughput negotiate a new ip address via a 6E connection? Is there a way to hand-off ip addresses to another AP for better connectivity, similar to cell phone/cell tower switching? Do I need a management system to accomplish this?1.1KViews0likes5Comments
