Tom_Manchester's avatar
Jan 21, 2025
Wireless IP address switching
I want to install eight WAX630E access points (APs) in a large warehouse. All APs will be hardwired on Cat 6 back to a gigabit switch that has a 2.5 Gb uplinked to a cable modem connected to the internet via Comcast. A typical user will be most often work at one location in the warehouse. On occasion they will move to another area in the warehouse and be closer to a different AP. Do they keep the original ip address or will the closer AP which provides better signal strength and throughput negotiate a new ip address via a 6E connection? Is there a way to hand-off ip addresses to another AP for better connectivity, similar to cell phone/cell tower switching? Do I need a management system to accomplish this?
  • schumaku's avatar
    schumaku
    You will operate all the wireless and wireld system on the same VLAN, so the same network. Handover is almost seamless, (certainly as long as you use WPA2-PSK, for WPA3-AES some assistance is required, Netgear Insight is your partner!). Of course, no IP address change will happen, No DHCP activity does have to happen, as to much time consuming. It's like quickly disconnecting and reconnecting an Ethernet link.
    Where I can't follow your intended plan is why you are for a single Gigabit Ethernet switch for the AP. Consider these APs are ble to provide (much!) more banwidth over the Wi-Fi. The aggregted wireless bandwidth of the WP630E is ways beyond of 20 Gb/s. If you think 2.5 GbE AP uplink i sufficient, look into the WBE710 (WBE71x) and some mtching 2.5 GbE PoE++ switch. If going to the top, look fir the WBE750 (WBE75x) and some 10 GbE PoE++ switches for this business Wi-Fi network.
    In case you need inter-VLAN communication on the same AP, the WAP630E isn't capable for this.
    Don't hesitate to contact Netgear's team for Pro WiFi Design Services for design support - it's completely free!
    -Kurt
    (not Netgear, just a good new friend from Switzerland for you!)
    • Tom_Manchester's avatar
      Tom_Manchester
      Hello Kurt,
      We're not using Insight. We have just installed three WAX630E APs spaced out in a building all connected via a switch to a cable modem router. Everything works OK, but once you connect one specific AP you stay connected to that one even if move and are now closer to a different one. Everything works OK but performance drops when roaming. Is there an easy solution for AP/cell switching?
      Thank you
ProSupport for Business
