yaboy713's avatar
yaboy713
Finding a mac address off a device on the switch
What are the steps to finding out the ip or mac address of a device that is connected on my switch? For example, if someone walks up and connect their device to a port on my switch, how can I view the device mac or ip address through the gui via ip address?
  • Carl_z's avatar
    Carl_z
    NETGEAR Expert
    Hi yaboy713,
    Wlecome to Netgear Community!
    You can view via Routing>ARP>Basic>ARP cash
    Here, it show us IP address,port,and man address.
    This function is not implemented on a plus switch,hope you are not using a plus switch .
    Regards
    Carl
    Netgear Employee
    • yaboy713's avatar
      yaboy713
      Thanks for responding Carl,
      I have a FS728TP. I do not see the Routing tab. Could it be a sub tab somewhere else?
      • Carl_z's avatar
        Carl_z
        NETGEAR Expert
        Hi yaboy713 ,
        :smileysad:FS728TP not implement with function of routing,so there no Routing tab.
        For FS728TP you can find at "Switching>address table". Here it show us all mac address that pass through the port  so you may see more than one mac address on a port.
        You can also refer to http://www.downloads.netgear.com/files/FS728TP_SWA_11Jan2010.pdf  page 107-110
        Hope it helps
        Regards
        Carl
ProSupport for Business
